Choppa's Performance Log
Choppa
Minooka, Illinois
Man soooo close, just can't hit them 12s yet. If I was on a track I would think I'd be there, but no spare time :(
20180504 154023
Does it show 60ft times? That is usually what needs cutting down to get a great overall time.
gimpy
Pennsylvania
+1
Not a 'bash', but you are using a "g-force" accelerometer, correct?
In my experience, they tend to time slow and me personally, I'd take that as 12.8-12.9 run.
I know a few guys use a GPS oriented app that produces times within a few hundredths of what their time slips stated while running a direct comparison at the track.
Maybe looking into the ones offered via 'Play Store' (or whichever app market you use) would settle your nerves a little.
gimpy
Pennsylvania
106 just seems like an unusually high trap speed in relation to the e.t. for an SHO.
These cars definitely shine to the 1/8th, then taper off.
Choppa
Minooka, Illinois
Unfortunately no
+1
Not sure what a "G Force" accelerometer is. This comes directly off my OBD2, not sure if that's what you mean. I have read that they can be off a bit. I'll definitely look into the gps app. Thanks.
106 is probably pretty darn close. By the time I took my foot out of it to start to slow I was at 110 on the speedo
gimpy
Pennsylvania
It basically measures the the force in any given direction caused by the movement of sensors.
There is probably a more technical term for them, however they became obsolete (and inaccurate) when compared to GPS timing.
gimpy
Pennsylvania
I meant in relation to your et.
For reference, I have trapped in the 106-107 range, but have yet to have a 13sec pass.
It could be in your short times.
Do you brake boost, roll into the throttle or let it chirp away, traction control on/off...even your tire pressure a few lbs too high.
You're looking at 5 hundredths of a second.
Realistically, that's 1/4 of gas and being sure to drop the Cosby's off at the pool before leaving home territory.
Choppa
Minooka, Illinois
For reference, I have trapped in the 106-107 range, but have yet to have a 13sec pass. Gotcha
In order for my gauge to begin logging I have to be at 0 so I can't roll into it. I'm sure I'm losing time due to the chirp chirp.
Thanks
mybigsho
new york
Check out this time slip.. All in the short time...
shobroooo
