Anonymous
started hearing a thumping / grinding noise coming from the front left wheel 1st I checked the lug nuts and they were tight 2nd I jacked the wheel off the ground and noticed a lot of play in the wheel everything is tight suspension wise end rod links etc... but I did noticed the there's play In the center hub allowing me to pushing the axle in a lil bit so I figured it was the axle nut and that's even tighten so could it be my wheel bearing ??
