Confused about camber bolts, H&R’s installed !
Daniel Hill
2017 PP Blue Jeans
Massachusetts
246E983F FE13 43A9 9695 77BD4B5FEDC6 50945635 97E0 4815 AF5C AEBFFE2929D0 2B211AED 0F9E 40C5 86D2 B1C07AA7EEBB i purchased SPC camber bolts part # 81280 after reading through past posts. I spoke with an rep from SPC and they noted a different part # for the rear 84130.
Are these camber bolts for the FRONT or REAR ? A local shop just told me today the fronts are NOT adjustable. True or False?
He’s willing to do an alignment for $89 WITH adjustment and $45 if the car is within factory spec.
Thanks!
bpd1151
Lurking Around
SHOcago 'Burbs
81280 is what I and a friend who worked in the R&D dept. at H&R came up with as a solution many years ago.
The other number being provided is from what I understand an "updated" part #, and is only slightly longer in length IIRC.
There is no option for the fronts that I am aware of.
Below is a "How-To" thread I authored many years ago on the subject.
http://www.ecoboostperformanceforum.com/index.php?topic=611.0
Best of luck and enjoy those H&R's.
BTW, the prices you've posted for an alignment are incredibly reasonable!
Daniel Hill
2017 PP Blue Jeans
Massachusetts
Thank you sir ! Much appreciated.!
glockcoma
Here’s the 84130 dimensions.
They are sold individually
The 81280 are usually sold as a pair.
I used the 84130 on my 2010 SHO and they worked perfectly.
Fee73bf03c99451f6d3fb8455a4aa75f
D564ee0d11a4d23809bda7f93b366992
And here’s the difference between
84130 and 81280
841300b3b96aa1709455009908f2847944415
8128097fb7d11adde310a5a54a5e06fc4fd6d
bpd1151
Lurking Around
SHOcago 'Burbs
Glock..... a point of clarification.
You compared a listed part of "81260" and the original part spec'd many years ago was/is "81280".
This variation is likely why you saw, or are seeing, the differences between the updated part number of 84130, and what others have used.
glockcoma
Thank you for the correction.
I just mixed up the numbers
The pic is the 81280
I’ll update my post
bpd1151
Lurking Around
SHOcago 'Burbs
No problem.
Just wanted to make sure the proper info is out there, that's all.
Regardless, both part #'s are functional (the 81280 and the 84130 that is).
The micrometer image is sweet btw.
Daniel Hill
2017 PP Blue Jeans
Massachusetts
I ordered the 84130 from Tire Rack. $20 A PIECE.... seems a bit ridiculous. But, some people have said their car did not need them. If that’s the case for me, I’ll return them :)
OmaHahn
Omaha
In my opinion I have NO clue how or why some people said they didn't need them! My rear camber was so off after H&R I could see it with my bare eye! The top of the tire angled in like a 16 year old's Honda slammed to the ground! The fronts were adjusted easily but the rears needed these camber bolts and it worked great.
