What is the extra button for
TomahawkSHO
All new cars have tire pressure sensors in them. Just comes on as low tire pressure when one is low. We cant see each tire which is a bummer.
It would be nice if it told us which tire was low...buuuuut...unless it was super obvious with the ***** eye, how many people would only top off the one low tire indicated and not check the others? Common sense isn't all that common.
Johnbigdog
michigain
This isn't Necesarily helpfully unless every time you rotate the tires you retrain the positions to the car. So even if it did tell you you may be inflating the wrong tire. I would not be relying on the service department to be training the tires every oil change. A pressure gauge isnt to expensive or big to keep in the glove box.
