SHO rear valve cover with oil separator
Sgtmeatsauce1
2013 SHO +pp
New Jersey
Ford wants 750 to replace my rear valve cover, pcv, and internal oil separator to stop my oil consumption and oil in passenger side intake. Does anyone have the part numbers for the New version valve cover, new oil separator that fits this new valve cover and the pcv for the 2013 SHO?
Gbczyk84
Provided by my local dealer, with their pricing. You could most likely order these online cheaper
valve cover AA5Z-6582-E, 209.03. includes gasket, vct seals and plug well seals.
pcv valve AA5Z-6A666-D, 10.58
separator AA5Z-6A785-F, 98.51
TA-357 silicone, 27.77
upper intake seals AA5Z-9439-BA, 19.52 X1 = 19.52
BL3Z-9439-A, 6.84 X 2 =13.68
AA5Z-9439-A, 4.18 X6 = 25.08
Sgtmeatsauce1
2013 SHO +pp
New Jersey
Awesome thank you, I found same parts, that what i trying to check, I found Tasca slightly cheaper but still shipping....my dealer wanted 340 for cover, 89 for separator 9 for pcv, not mention all that other stuff....i not even truelly sure that the problem. I consumed 2.5 qts oil in 6000 miles 5w-30 pennzoil ultra platinum. Oil all over the passenger turbo, oil in intake passenger side but not aircleaner side....and I had a RXP dirty side clean side oil catch can, which had mainly water and fuel in it. Car does not smoke, on start up cruise or WOT.....they replaced the bank 2 cat under warranty....
Gbczyk84
Sounds just like mine, rear turbo replaced under warrenty for oil leak, don't think the old one was bad. Then they offered the valve cover deal, I have not yet done this. No issues with the motor besides oil in the intake pipe/rear turbo. Using Magnatec 5W30 myself. Just over 102K miles, 2013 PP
Sgtmeatsauce1
2013 SHO +pp
New Jersey
I only have 55,000, I am actually going to run the Magnatec next too, has great reviews for ecoboost type motor...how much oil does your eat? Not sure why only oil on passenger side intake and down on the turbo, really not sure why my RXP catch can did not help. Not sure if I will go through all that if it not really going to fix the problem. I think the oil the culprit that killed my cat....
Gbczyk84
Oh my rear cat was replaced at 70K miles as well. Forgot. Mine doesn't consume more than half quart in 5K miles. Been using dealer oil changes until I switched to doing them myself.
Sgtmeatsauce1
2013 SHO +pp
New Jersey
Btw....what are all those other parts for, after the silicone sealant.....intake gasket etc?
Only have to take off intake if you are doing the front valve cover not the rear firewall cover that has the separator .
Gbczyk84
The other gaskets are for the intake manifold. Not sure why that's included since you should not have to remove it for the valve cover.
Sgtmeatsauce1
2013 SHO +pp
New Jersey
Ok I went all the way to Ford customer careless, my certified 2013 SHO that is using oil, TSB- 15-0086 would be covered under extended, but not certified warranty, or would be covered under emissions warranty ONLY UP TO 50,000 MILES, other parts like the cats are warranted to 80,000 miles. So if your vehicle is smoking or using oil and it all over the intake hoses etc, get it done before 50,000 miles. Ford want $750 plus tax and misc to do. Parts can be had around 200+ plus shipping and tax for the forced DIYs. ....this must eventually be done because the excessive oil will **** you cats, like my bank 2 cat.....good luck.
Gbczyk84
Has anyone done the TSB and can offer any feedback? I still have yet to do on my own vehicle and am hesitant to give Ford any more $$.
Laser411
Why would this be an entire valve cover and not a gasket? Something special about this valve cover?
