Disclaimer: Links on this page pointing
to Amazon, eBay and other sites may include affiliate code. If you click them and
make a purchase, we may earn a small commission.
If I had a 13.5:1 engine,I think I'd stick with nitrous.....if it's running 11.5@119 NA,it should run 10's on a 100 shot if it hooks and doesn't break.
Those new baby Borgs with FMW are cool! I like the spot for the rpm pickup. And they are priced right!!!
The pistons are 12.5:1 and the heads have been skimmed. Additionally, IIRC it has SS Stage 2 cams (or equivalent). It is running 11.55 with a 100 shot of N2O... Same power with the 1/2 mile run as well. If the motor wants to push out head gaskets before making desired power, there is a backup, low compression motor ready to go.
I wouldn't call this a baby BW turbo as it is still a 79 lbs/min turbo.
Once you've run a few s400 chargers,anything else is a baby.
I was under the impression the 11.55 was NA.......I'd still add more nitrous b4 going turbo.....just because it's there and to see what parts will break with a turbo.
Car is still running strong...and I think a .030 cut is just enough to add 1 point of compression.
If there is any interest in N2O after this point, it will be in addition to the turbo, not deplete-able replacement. 150 shot isn't going to get us the 300 more whp we want.
If I wanted to brag about banging a Kardashian it sure as shit wouldn't be Khloe. With that in mind, if someone was claiming that i might give them the benefit of the doubt.
Hey Broke1, I guess you haven't been around very long but that 430 hp is an inside joke. Nobody ever claims more than 430 hp, ever. It is an unwritten rule among the forced induction crowd.
