94shodriver
I have had a lot of success using my C5 set up on the track, having taken 4 full track days to wear down the pads to 2mm in spots and plenty of life left in the rotors. However, the pedal feel leaves something to be desired. Basically the top half of the travel is very good with good linear bite to pressure. After about a moderate amount of braking, if I apply more pressure as if to brake as late as possible, then the pedal feels mushy on it's way to the floor until I get ABS activation and the pedal comes almost all the way back up. I don't recall when the car really developed this issue as I don't use it consistently enough. I flush the fluid every year and did it just a month ago, as well as bleed before each track day. I have used the ABS activator to flush the ABS block, but not as recently. I'm running Raybestos ST-43 pads up front and Stoptech street performance in the rear. Every other car that I have used the ABS in under hard braking just pulsates at the point of lock-up, not pushing the pedal back up in travel a significant amount. I'm thinking air in the ABS block, master cylinder or cooking the pads, but pad wear rate does not indicate that. Thoughts?
