avatar28
Uh, one other thing. Should I be able to turn the compressor shaft by hand? Several people seem to have made references to turning it with their fingertips but I don't seem to be able to do that.
What did you use to reach the snap ring? I've yet to find any tips that are the requisite inch or so long. Someone suggested using modified allen wrenches but all the ones I've been able to find have an angle running along the bend.
However, if you cannot turn the compressor over slowly by hand, then the compressor is toast and you need to abandon this mission and just get a different compressor to put on there.
I used some modified allen wrenches for tips on a mulit-tool, used a Dremel to shape the tips and bent them to fit. Even then there was too much leverage, and needed to wedge something between them, its been a while, don't remember what I used.
No, not yet. I've got the front wheels up on some concrete blocks. I'd have to put the battery back in and start the car to get it back off. I can lay on the ground and get to it from below but the space is even worse that way. Going at it from the top has been much easier thus far.have you pulled the plastic wheel well liner back to see if there is a way to get to the ring by going in fromm the bottom?
So even if I get it off a little, it's going to want to snap right back into the groove. Fun times.by the way that ring is tapered. the inner part is narrower than the outer. the purpose is to wedge into the slot and put rearward pressure on the coil plate to hold it firmly against the compressor.
I think that's where I'm quickly headed towards. I've heard that I have to put a jack or something under the engine to support it when I unbolt the compressor? Is that correct?as stated, you most likely need a new compressor. You can remove the mounting bolts and tilt it back to access the ring without breaking the refrigerent lines. That way if you don't want to completely fix the AC now you can just put a new pulley on, then drive it.
I did that on its own. When I removed the nut and the disk, that part just fell off into the bottom of the engine. I didn't even realize it until I tried to run the car with the disk off as a test and the belt didn't move.I'm curious, did the pulley fail into 2 pieces, or did you cut it to remove it?
just took another look at my broken compressor. If you need the drive the car without AC, leave the coil alone, just be sure the debris does not interfere with the new pulley. put the pulley on, ring on, belt on and drive.
