Anonymous
My tachometer and gas gauge stop working along with the temp gauge ...only gauge working is the speedometer what could have stop that ???
Ditto.check electrical connector to instrument cluster, fuses for instruments, etc.
I can't recall going underneath the dash for anything what's weird is that the gas gauge is stuck at a 1/2 tank and my temp is stuck at the H markDitto.
Have you done any work under the dash recently?
I haven't seen any warning Lights but the blue high beam indicator comes on when I turn on my high beams that and my signal worksDo any of the warning lights come on? Turn signal indicator, high beam?
So I should pull out the cluster and check all the connections?there are two connectors on the back of the cluster. if one is unplugged or corroded you could have those symptoms. or if a ground is bad you could have those symptoms.
