RPM tach and gas gauge not working
Anonymous
Philadelphia,PA
My tachometer and gas gauge stop working along with the temp gauge ...only gauge working is the speedometer what could have stop that ???
check electrical connector to instrument cluster, fuses for instruments, etc.
NOTAURIUS
I agree, the wide electrical connector could be unplugged or the printed circuit board is damaged. The speedo works because its the only gauge run by a cable.
there are two connectors on the back of the cluster. if one is unplugged or corroded you could have those symptoms. or if a ground is bad you could have those symptoms.
Anonymous
Philadelphia,PA
So I should pull out the cluster and check all the connections?
Slo-Sho
It wasn't me!
Crossroads, CNY
If the cluster hasn't been disturbed I wouldn't pull it out just yet. Check fuse number 18 (10 amp).
Lcasho92
