Iron Bender
Tom,
the paper sticker on the PCM reads H3Z1. Tonight I traced all the grounds. I went back and traced every wire outlined in the other woman article (although I used a CCRM vs individual relays). I grounded the injectors first during crank mode then directly without cranking and then made a LED test light wiring it backwards. No pulse on any test. Being aggravated I pulled the injector rails to bench test the injectors on low amperage. Small sparks when connecting the circuit but no clacking or any kind or any movement I could feel in the injector. Just pure silence. This must not be the way to test an injector. What additional information can I provide???
Jim
Jim
