you cannot see anything except possibly the top of a piston when you pull a spark plug.
to see the injector o-ring, you need to pull intake and fuel rails and remove injectors. most of the ones I have had out lately, the injector o-rings were pretty loose, so its certainly possible to leak.
there is a way to confirm that the oxy sensors switch, it involves wiring them up and heating with a torch - search online and you can find instructions I'm sure.
