3.2L Lower Idler Pully
Aqua Roach
Deadly Insane
Concord, NC
Hi, I am in need of replacement for my lower idler pully. I've looked online and I cannot find one for a decent price. [SHO Source wants $80.]
AZ doesn't have it.
I can find Vulcan ones for $10 anywhere, so something like $20-$30 wouldn't be too far out of question.
The bearing is really the only problem, last resort is having it pressed out but I know people want an arm and a leg for that too. [Had to do my hubs recently.]
Thanks!
LOUDSHO92
Rancho Cucamonga, CA
We have both the bearing and pulley here: SHO Source
As afar as using bearings from otehr cars they may not last long. We get a lot of pulleys with the wrong bearings because they did not hold out.
NoSlo
SHO Owner
Portland, OR
I've got a used one I could part with for the $40 shosource core charge, + whatever speed shipping you desire, PayPal or Bitcoin. The one I'd sell would be one that's been in my car working fine; I just swapped all the idlers to discover it's something more expensive in my car making a squeak.
If it's just chirping, I've quieted the upper style by injecting them with a syringe needle of wd-40, tranny fluid, then gear oil and working each through the bearing. Only good if the bearing is not damaged, you want it to spin without any crackly feel from a flattened ball bearing.
brianwil2727
Mumbai
If it's just chirping, I've quieted the bitcoin futures fund upper style by injecting them with a syringe needle of wd-40, tranny fluid, then gear oil and working each through the bearing. Only good if the bearing is not damaged, you want it to spin without any crackly feel from a flattened ball bearing.
thanks for this information
