More digging... Please read the entire article...
Date: Thu, 29 Oct 1998 19:35:32 -0700
Reply-To: [log in to unmask]
Sender: Ford Taurus SHO Discussion List <[log in to unmask]>
Subject: Re: SHO trans was 3.0 motor in Junk yard
Comments: To: "Benjamin J. Bentley" <[log in to unmask]>
Content-Type: text/plain; charset=us-ascii
Sorry yesterday I made a mistake. The Tempo got the V-6 and the MTX IV
in 92 not 93. To everybody the answer to Joshua's question I am sad to
say is yes it is only the V-6 tempo's with the MTX IV (The MTX III will
bolt up but may not last very long). I believe that 50,000 V-6 tempo's
may be about right but most were ATXs I believe about 20,000 MTX were
built but not sure. that's 20,000 more MTX IV's out there than just SHOs
though.
As for the probe the parts catalog give's a different part number
for the cases halfs than the SHO or Tempo. What else is different I
don't know. The 3.0 probe uses the same trans as the 2.2 turbo with a
different bell housing case half. The guts may be the same though I'll
see what I can find out.
Matthew Hepner
Benjamin J. Bentley wrote:
> The MTX IV was also used in the 4 cylinder turbo probe and the mazda
> version
> of the same car.
> Ben
> ASE Master Tech
> Modified '93 Auto 73K
http://www.geocities.com/motorcity/downs/8150/sho1.html
> SHOtimes Directory updater
http://www.shotimes.com
> [log in to unmask]
> -----Original Message-----
> From: Matthew Hepner <[log in to unmask]>
> To: [log in to unmask] <[log in to unmask]>
> Date: Wednesday, October 28, 1998 11:34 PM
> >Dave, Marcus, Paul, Joshua and other list members please read the
> >following it may be long but I believe worth it.
> >When I had my '69 mustang fastback I knew The inter changeability of
> >most of the parts so that I could take a part off a '70 cougar if
> >needed. As our SHO's get older this same knowledge will be very
> helpful.
> >The history of the SHO trans ( MTX ). before the SHO the MTX trans
> was
> >in an ****** or a tempo as an MTX II (4-speed) or MTX III (5-speed).
> >when the SHO came along Ford took the MTX III and added bigger
> bearings
> >and wider gears for strength and this is the MTX IV all else is the
> >same. the MTX III was used in the tempo until '93. In '93 the tempo
> got
> >the 3.0 V-6 and along with that the MTX IV. The difference between
> the
> >MTX III and the MTX IV is very small allot of parts will exchange
> and
> >the physical size is the same. I have seen quite a few V-6 tempo's
> and
> >am sure like the SHO sold better in different parts of the country.
> they
> >sold better at higher alltitudes because of the better power.
> >I work at a FORD dealer and spent sometime today verifying this
> before I
> >looked like a fool so here is some proof. Ford's part numbering
> system
> >includes a "code" for determining which vehicle line that a part was
> >originally intended for. for example and F3ZZ pre fix denotes a part
> for
> >a 93 mustang although it may be used on a 95 T-bird .
> >using this here is what I found.
> >both case halfs are '93 tempo parts
> >the main shaft, countershaft, output shaft and the differential
> carrier
> >are 89 taurus numbers but are also used in the '93 tempo
> >the shift forks shift rails and syncros are 88 ****** numbers for
> both
> >the SHO and the tempo.same parts as the MTX III
> >I didn't have time to check every part but I think you get the idea.
> the
> >final drive ratio may be different both have the same listed but may
> >vary from car to car depending on options. for instance high altitude
> >vehicles sometimes have lower gear ratios to make up for the loss of
> >power
> >Matthew Hepner
> >Dave Kegel wrote:
> >> I choose "or not". They are not the same.
> >> Dave Kegel
> >> From: Matthew Hepner [mailto:[log in to unmask]]
> >> Sent: Tuesday, October 27, 1998 10:24 PM
> >> Subject: Re: 3.0 motor in Junk yard
> >> Believe it or not the transmission case and all the internal parts
> are
> >> the exect same as, are ready for this a 5 speed TEMPO/TOPAZ there
> are
> >> tons of these out there.
> >> Matthew Hepner
