2013 acceleration hesitation rough shifts
markathome
2010 SHO
VA
Check the wires for chafing, if that isn't it, find a new dealer. Call Ford and ask for a reference to another dealer. I had this happen 'once' back in early 2011 before any of the applicable TSB's where performed. After I had the TSB's done on my 2010, I've been issue free for 2 years. The TSB's list here on the Forum looks to be applicable to 2010's. I'm not sure if there are any new TSB's for the 2013 models...anyone have access to check on those?
Good Luck...
aaronjohnson
Walled Lake, Michigan
There is a recall issued this past week regarding the Fuel Delivery Module. Perhaps this is causing your issue?
Title: FUEL DELIVERY MODULE REPLACEMENT
xujn
Tivoli, NY
I checked the wires and they are not chaffing, they're actually wrapped already. I also checked that recall and it does not apply to the 2013 SHO. I'm taking the car in on Friday to service the Advance trac and they said that they'd take another look when the car's in. Thanks for the replies everyone
13-SHO
Detroit
They will replace the part under warranty right now if you smell gas or see a leak.
I doubt this is his issue. (A fuel issue caused by a broken adapter would be present at any throttle position.) Without seeing it, it could be anything from a sticking throttle plate, bad ignition coil, dirty injector to even a possible leaking valve (very doubtful!).
He will have to replicate the condition with a tech in the car. It's the only way.
xujn
Tivoli, NY
That's what I'm planning to do, but looking at reviews online there isn't a "good" ford dealership within 25miles from where I live. =( guess I'll have to put this off until I have more free time.
Mac98SHO
Pine Island, MN
Do you have the hesitation all the time?
I sometimes experience a hesitation on initial start up(depend on how cold it is) if I don't give it few seconds to idle down, after that it is smooth and responsive...
LotusDriver
Rocky Hill, CT
My 2013 Explorer Sport has done it. My 2010 SHO was bought back by Ford for doing it. To those trying to diagnose this here on a forum, you won't, unless you have experienced it. This is not normal hesitation. There are TSB's on this, and a simple reprogram SHOULD correct it.
krewat
Long Island
Mine does something similar. I find that if I "roll" into the throttle, it's pretty much gone. It's not a "lean" hesitation, more of a feeling that the computer doesn't believe that you slammed on the go-pedal that fast. It does't bog down, it just keeps doing what it was doing before I slam on the pedal.
I'm wondering if Ford didn't go a little too far in programming the computer to be careful in terms of the fly-by-wire throttle.
One weird thing, if I clear the KAM (keep alive memory), it stops doing it for a while until the computer relearns. Which means that for one thing, it's not the throttle plate or actuator sticking.
I also had a "cam A too ********" code a few times right after I got it brand-new, but after an oil change at 5500 miles (I'm at 7500 now), that hasn't come back. Coincidence maybe.
ALSO, I noticed that certain brands of gas make the hesitation worse. As if it's related to octane. Again, maybe Ford being too careful, but about detonation.
Mac98SHO
Pine Island, MN
I have had it stumble on cold morning on initial start and go ..... so now I give it a sec to catch itself...If I remember right I had the cam code thing also... but nothing since I got to 5k and oil change.
I will have to pay attention to the fuel type see if I noticed what you noticed.
xujn
Tivoli, NY
I too have noticed that a more gradual application of the throttle helps to eliminate the hesitation feel. If you wouldn't mind explaining how do you clear KAM? I've only used Shell's 93 v-power, with the exception of putting 91 in it once when I drove to Ontario. I think that a tune might very well solve this issue, but don't feel like voiding my warranty.
xujn
Tivoli, NY
So.... my car woke up! :hail: I decided to plasti dip my wheels today, and stuffed plastic sheets around the brakes to mask them off. After I was done plasti dipping I wiped the rotors down to make sure there wasn't any over spray, and found that they felt greasy. When I took it for a spin it felt as though I was driving an entirely new car! I'm not sure if it was wiping the rotars down, the plastic sheets hitting something, or if it was the result of me driving the car fairly hard in the morning, but something worked. I just hope that this isn't temporary though.
Wonder if the wheel sensors were compromised, and your cleaning the rotors took care of that. How's the braking performance?
xujn
Tivoli, NY
Braking was never a problem, but I have always found it harder to modulate the Sho's braking compared to other cars.
krewat
Long Island
Just got back from the dealer, with an update.
First, I can clear the KAM with my SCT X3 tuner with the latest firmware. I got it with custom tunes from Mike @ 5-star (sponsor over at ford-trucks.com) for my F250 V10 6.8L.
I can read/clear DTCs and do data logging on my '97 Cougar 4.6L, '01 F250 V10, and now the 2013 SHO.
You can also clear the KAM by pulling the battery for an hour I think, but not sure about the brandy-new cars yet.
Now for the good part (at least, I hope it's good over the next few weeks).
Went to the dealer last week and made an appointment for today, got a few TSB's taken care of (GPSM update, as well as a steering wheel module update). Complained about the hesitation. Told the service writer that I had heard there was a throttle-body and calibration update for that. They did the calibration update, but no throttle body relacement - yet.
Drove it home, and the shifts are MUCH BETTER. Before, it would actually let off the throttle during the shift, so it was like driving a manual tranny. Now, the shifts go through without any lessening of the throttle.
Throttle response seems much better as well. Can't really say the "total lack of response" hesitation is gone yet, but the throttle response got better and better as I drove it home. Over the next few days, I will see what happens as it relearns.
Old calibration code (strategy, according to my SCT tuner): KHDK2K5
New calibration code: KHDK4K5
Side note: The TSB's I brought it in for were:
13-3-11 - GLOBAL POSITION SATELLITE MODULE - TRAFFIC DIRECTIONS AND NAVIGATION - UNABLE TO LOCATE VEHICLE - BUILT ON OR BEFORE 1/15/2013
http://www.fordservicecontent.com/Ford_Content/pubs/content/~WT/~MUS~LEN/3539/tsb13-03-11.htm
http://www.fordservicecontent.com/pubs/content/~WT/~MUS~LEN/3539/tsb13-03-11.pdf
I had some of the symptoms, but not all.
13-1-1 - EASY ENTRY/EASY EXIT FEATURE - POWER TELESCOPING/TILT STEERING COLUMN DOES NOT RETURN TO CORRECT POSITION
http://www.fordservicecontent.com/Ford_Content/pubs/content/~WT/~MUS~LEN/3513/tsb13-01-01.htm
http://www.fordservicecontent.com/pubs/content/~WT/~MUS~LEN/3513/tsb13-01-01.pdf
After reentering the vehicle, the wheel wouldn't return to the exact same place I had it before. Which is down all the way, and all the way out. Now, it not only returns to the same place, but ALSO seems to extend further out towards me when I use the controls to move it. Which is where I like it.
I will be writing these up separately in another thread.
xujn
Tivoli, NY
That sounds great! I'll definitely bring up the steering module tsb when I take my car in for the gpsm tsb. I had brought up the throttle body tsb before, but my dealership wouldn't do it as they couldn't find the problem. >=(
However I did learn a "trick" over at ecoboostowners and apparently we are able to calibrate the throttle body ourselves!
1. put car into accessory mode
2. push the throttle all the way to the floor and release
3. start the car as usual
can't say whether it works 100% or not, but I know that since I've done it there hasn't been any hesitation.
krewat
Long Island
Since the update, I've noticed the car does do the hesitation thing, just not as bad, and today on the way to work - really only the second full commute since the PCM update, it didn't do it at all.
I notice the car is more "brutish" with the update - better throttle response, especially in regular "Drive", and shifting is much improved.
Still not sure if the hesitation is completely gone. Will keep this thread updated if I notice it (or not).
I have to try that recalibration - I know there was one for the trucks, especially the Superduty that was a little more involved than one foot-to-the-floor cycle, but I'll give it a shot and see what happens.
krewat
Long Island
Tried that recalibration, and it seems to have made a difference yet again. Even more stable throttle response... will report back after a few more days driving.
