Does anyone have a picture of the ECT sensor location??
SHObogdan1
Michigan
Hi, I know that the gen 2 Taurus SHO's have two temperature senders, one that goes from the thermostat gooseneck area to the dashboard gauge, right? I can't seem to locate the other. Does anyone have a photo or a link to a photo for the ECT sensor (the one that goes to the PCM). Thanks!
Off Road SHO
Moderator
It is real close to the other sensor, the one you found. It has two wires going to it.
Tom
SHObogdan1
Michigan
Aaaah ok, I think I found it on my car, it's mounted at the rear of the engine, right next to the transmission fluid dipstick, correct? And just to make sure, the temperature sender (the one right next to the thermostat gooseneck) is the one that sends the temperature to the dashboard, right? And the one at the rear of the engine (right next to the transmission fluid dipstick), that's the ECT sensor that sends the temperature to the PCM and turns the fans on, correct? Does all this sound correct, or is it the other way around? Thank-you for the autozone link too, that was great!
SHOtimer
#2910
Santa Clarita, Ca
Yes.
Doug
Lcasho92
