Time for some fun!!
jayro
Auburn, In
UPS delivered a package today. Can't wait to try these out!!!
image.php
image.php
jayro
Auburn, In
Nice! Which Brake set-up are you running? '96 Big Brake Upgrade? Cobra Upgrade?
I am running the '96 front brakes with stainless lines for the front. Rears are stock with the prop valve help at full open with a clamp.
I ran the Carbotech AX6 pads (more of an autoX pad) with this setup last year. Tires were Hankook R-S3's. The car stopped very well and I could kick in the abs if I wanted. 20 minute track sessions without any fade. The drawback was the AX6's wore VERY quickly when tracked since they are not designed for it. The XP10's are a track compound, so they should wear better.
Ishodu
You will be very happy with them. My first set of xp10s lasted a long time. I am only on my second set since the Convention track day in Waterford hills. They were done by the end of the day at BIR last summer.
Make sure to get a pic when they turn white :)
jayro
Auburn, In
Will do. I did that to my AX6 pads. I also bent the edges of the pads, they tapered away from the rotor at the edges, and turned my plastic valve stem cap into a misshapen blob.....:evilgrin:
