I'm not sure that you took those measurements in the right location for "B", however less than 5 ten thousandths is darn good. I could live with half a thousandth all day long and twice on Sunday.
Do you want to borrow my ball end hones? Mitzi is getting ready to head South.
Tom
The cylinder bore diameter rubydist provided me was - 3.6220". But I don't know if that's the max or the min. If its the min, then adding the tolerance of .0012" gives me a max diameter of 3.6232".
I multiplied x .0045 top and .0055 for the 2nd to get the gaps. I went with a slightly larger gap just to be safe. The DNJ's out of the box gave me .0014 and .0016 from what I recall. I ended up with .0017 and .002.
not a bead, just a dab where the valve cover gasket fits.
hopefully you also put a dab on at the edge of the cap where the seal fits.
Well I've got some dimensions, but I'm not sure I want to make any decisions based on them. The gauge I'm using is a little flacky and if I tighten it incorrectly it changes the gauge setting. I had to redo each measurement several times to make sure the gauge fit snug again, after I removed it.
I made two measurements near the top. One (A) at .25" below the bottom edge of the chamfer - where the cylinder coating material starts. The other (B) is .75" down from the face of the block. This is equivalent to top travel of the oil ring.
- A) = 3.6229 (.0003 under max)
- A) = 3.6225 (.0007 under max)
- A) = 3.6224 (.0006 under max)
- A) = 3.6230 (.0002 under max
- A) = 3.6231 (.0001 under max)
EDIT: Remeasured using Tom's inside mic as a gauge then measured using my outside mic, and at the position he suggested (top ring - 3/8") and averaged for perp & para measurements. I updated the numbers above.
