Getting down to the wire here on bench test of the 914-SHO motor. I have two startup tests on my check list; 1) Oil pressure check, 2) Base idle adjustment.
Here's my procedure for the Oil pressure check. Let me know if I'm missing anything (new to SHO motors).
Pre-start check list:
Starting Sequence:
My other question is about the Base idle adjustment. Since the idle speed controller is disconnected - does the adjustment have to be made with motor at normal operating temp?
TIA
- Remove spark plugs to ease engine rotation
- Remove 4-wire connector from coil pack
- Check wire from oil pressure sensor to idiot light
- Check oil level
Starting Sequence:
- Key in Run - oil press light is ON
- Key in Start and cranking
- Oil press light should go out when min oil pressure is reached (or 1 minute - which ever is first)
- Turn ignition OFF
- Re-install plugs and coil pack connector
- Restart motor and allow to run - oil pressure light should be OFF
TIA
