vortex2450
Buying Parts...
Hey guys,
I searched some but didn't find anything conclusive.
My front suspension is pretty wacky right now. The car won't keep an alignment and the right side makes a dragging/clunking sound when I turn the wheel either way at low speed/or a stop.
Coincidentally the same side was exposed to hitting a gruesome pothole @ 45mph which destroyed the LCA, this happened a couple months ago.
I believe it's the culprit because I don't remember this problem before hand.
So I'm diagnosing this to be strut mounts, I'm ordering a set of Ingalls adjustable w/ bearing from SHOsource but I am hesitant to tear apart my front suspension for the 3rd time this year in my DD before I have a clear idea of what needs to be done.
When replacing the mounts which way is deemed the most "efficient"?
I have two trains of though here.
A) Removing the whole strut/spring/knuckle assembly. This would involve have to remove the brake calipers, loosing the axle nut, fighting the axles out, removing the lower ball joints and unbolting the three nuts on top of the mounts right?
I don't really want to have to fight the ball joints again, they were hard enough with two people the first time that I had to reinstall them.
B) Have the suspension in the air (obviously) and disconnect only the strut assembly and beat the shit out of the rusty connection between the strut and the knuckle, but I am wary, I don't if I'll have even room to maneuver the assembly out without having to go through a couple of the steps in plan A.
I know someone here has torn this stuff apart enough to know how to do it in their sleep.
Any input is great.
Thanks,
Josh
Any input is great.
Thanks,
Josh
