vortex2450
Buying Parts...
Thanks for remembering me.:wave:
My procedure above was to get the strut and spring assembly out of the car. Once out, the spring compressor is then applied to protect you and the surroundings when the top nut is removed from the strut. With shorter, higher rate springs such as the Eibachs on my car, I need use only hand pressure to compress the spring enough to remove all spring load when removing the nut.
Either way, once the top nut is installed on the new mount assembly, the spring compressor is removed before the strut and spring assembly is reinstalled in the wheel well. I install one nut (inboard) loosely on the strut mount studs protruding from the strut tower to suspend the assmbly in the fenderwell. I then use the 2"x2"x4' lumber to lower the knuckle enough the slide the bottom of the strut into the knuckle. A bit of muscle is applied to align the knuckle with the strut to allow the strut to slide into the bore of the knuckle. I use the same bottle jack below the lower control arm to slowly press the knuckle onto the strut far enough to align the strut pinch bolt with its hole. Go too far and the bottle jack can be again used to slide the knuckle down the strut to align the pinch bolt for installation.
I have done this a few times with much success.
Thanks for the detailed procedure, it's certainly going to help.
I order the mount yesterday. Kevinspann is talking me into doing a gen3 brake upgrade when I do this as well.
-Josh
