88GTA92SHO
aka NCtaurusSHO
That would be a fun install
Hope you guys and gals are ready to hear a 2010 SHO with some Magnaflow exhaust on it.Spent about and hour today and slapped some on the car. Ought to be broke-in for sure when I come to see everyone in a few weeks.
I need to install some rear springs in my 91'. I have a set of Moog Cargos and I am unable(because of my back issue) of installing them at home. If I bring them to the meet, could someone help me with the cutting(want to remove 1-1.5 coils) and installation? Any help would be greatly appreciated? :thankyou:
(I do it next week) well here It is about 17,000 miles later!!!! Burns more gas & bogs it out of the hole a little & no 4000 rpm action, but U press the gas & it's still ON LIKE A *** OF GRITS!!!!! Needs Breaks & rotors too!!! ANYWAY DJ I'll help in anyway I can!!!!!
Congratulations Paul. I think you just went from sho meet to sho week. That sounds like lots of work going for one afternoon. Good luck guys and gals! Don't forget to tip your mechanic.![]()
I wish. The oil is leaking like a sieve and I just patched a lower heater hose that ripped this week. I could use the shop access to get'er done, but then again it looks like a full slate of small and large projects that day.
No time. I took in one of the clients at home and might take another next month. It takes alot of maneuvering to get someone to watch the guys. Can't believe this thing stills runs at 199+k with the limited maintenance I have time to perform. I definitely got my moneys worth on this thing.
Saw your Gen4 when I was going through Pungo last week. Looks great.
Hope to get all of my oil leaks fixed before the meet.
Mine may be leaking from there even though I did VC gaskets already. Front end is pulled apart for cam and crank seals, and oil pan may have to come back off for resealing. This damn thing WILL NOT leak all over the place.
