You might want to think about swaping to the gen 3 subframe.
If you dont mind can you explain this a little bit to me? I owned one sho before and loved it but didn't really do much research about it. The one I just bought needs to be restored quite a bit. Can I just get what your talking about from one at the junk yard? I would really appriciate any advice on my rebuid. Thanks!
Not to be rude, but do a search. Its been covered in detail many times just recently.
Ok so I did the search and found some of the info on what to grab, but I guess my question is why? Is there something wrong with the gen 1 front supension or???
Better suspension geometry (control arms), the awesome Gen3 ZF steering rack, and bolt-in (as opposed to the stock Gen1/2 pressed-in) front bearings. There may be others, but those are the big ones I'm aware of. Essentially it's just an improved design.
Not sure what thread you came up with, there are some with pictures, but heres one that explains why its a beneficial swap:
Also people say it makes for less wheel hop and better 60ft times, if your into that.
gen3 subframe thread, click me.
Normally I would agree in the search, but he didn't start this thread asking questions about the Gen III swap, it was suggested to him. Given that, it would help him to point him in the right direction or give a quick brief on the subject.Not to be rude, but do a search. Its been covered in detail many times just recently.
It's winter in **** too
04mystic - Here in Colorado are you located?
I'm going to replace all the bushings in the front supension here pretty soon. Has anyone else done this lately, and if so where did you buy your bushings from? Is there a kit that is a good deal?
No question about it, replace them with Energy Suspension parts. Energy Suspension PN 4.7119G is the kit for the tension rod bushings. Have the cups welded before you take it all apart. Also before diving in, check for play in the inner and outer tie rod ends. Replace as necessary. Energy Suspension 9.5160G is the kit for the front sway bar bushings. They come with straight grease fittings installed, but replace them with 90 degree fittings. Shop Energy Suspension parts at Autozone, Amazon, and SHO Source.
