Wobbly speedo
cmwwit
PA
Hello, my speedometer needle wobbles all over the place and its driving me nuts! any solutions? Thanks, Chris.
greengiant
Holden MA
join the club, everyone who owns a sho, taurus, or sable has this problem. speedo gear gets frigged up if i recall correctly
SinisterSHO
Rust free
630, IL
i believe sometimes its the cluster. It was explained to me once, but I do not remember what exactly the issue was. Mine bounces all over the place or will just say I'm doing about 30 MPH more than I am.
Amy Witty
Bangcock
i have the same problem, and as it was explained to me before, its the speedo cable, best i can remember
Art5
white plains, NY
I have the same problem now. Changer speedo gear in transmission, cable, so I think it is speedometer itself. I think in my other car years ago, was the same storry, but ended with ,,,ha-ha, 292000mile speedometer , that I had to put on the car.
Phokus
Vroom Vroom
Quincy, Massachusetts
My speedo needle only wobbles on the current speed (like if 30 it'll jiggle around ~28-32) if I let off the clutch and gas and let it coast down the highway. Stops wobbling when I press the clutch in and continue to coast or if I accelrate
I've only seen this happen on MTX cars so I assume it's just that?
JRA2000TL
The Complainer
Daphne, AL
You could try lubing the cable first to see if that helps. That's a quick/easy thing to do. NAPA sells some kind of special speedo **** IIRC.
greengiant
Holden MA
my friends 94 slo had the same problem, so its something slo and sho have in common
gmail
Well-Known Member
sunbury pa
mine did that before the cable went bad, other then that i never had a problem with speedos in SHOs
Jh8990
New Jersey
white lithium grease. but you have to get the spray kind, not the kind in the tube. and watch where you spray it because it can go everywhere.
ask me how i know.
cmwwit
PA
Hello, ok so now my speedo isnt hardly wobbling at all but it is making alot of noise. How hard is it to get to the speedo cable to ****? Do i need to take off the instrument cluster? Thanks.
Jh8990
New Jersey
yes you need to take the instrument cluster out. If you've never done it before be patient so you don't break anything. I can get mine out in around 10 minutes.
this link might help a tiny bit.
http://www.shotimes.com/php-bin/mod...e=article&mode=thread&order=0&thold=0&sid=213
cmwwit
PA
Ok so im finally going to try to **** my speedo cable, i cant take it anymore! My question is, where the cable goes into the transmission there is a metal clip on the end of the cable that looks like it needs to be pulled out to remove the cable. The problem is i am scared to remove it because it looks like i wil have one **** of a time getting it back in! has anyone ever done this??
cmwwit
PA
Ok, so has anyone ever taken their speedo cable off at the transmission? Id just like a little input before i go trying to take out that metal clip..:nut: Oh its a 92 MTX. Thanks.
StAnGbAnGeR
NavistarEngTec
Homer Glen, IL
I would like to know this too. My speedometer doesn't work at all. I pulled my cluster partially out today, just enough so I can fit my hand on the back of the speedo. My speedo cable is connected, so I'm thinking it's not connected to the trans. Is this easy to reach from underneath?
cmwwit
PA
Stangbanger, if you look at your firewall you can see the speedo cable coming out and going into the transmission on the top, so its accessable from the top side. I just dont know if i can just pull the cable out from the tranny without any damage or issues putting it back in and nobody seems to answer this question......:wave:
stangeater
Farm Boy
Same here! Usually your speedo cable is going bad when it wobbles all around. Easy fix too. Get another from a junk yard...
quikSHOilver
Yamahaized
Indy
Speaking of clip on speedo cable between mtx just above vss... dont remove the clip completely, instead just pull or tug the clip nearly halfway and hold it there while using your other available hand and pull the cable straight up. it will pop out without ill-effect.
