Rubix
- Joined
- Jan 12, 2005
- Messages
- 1,329
- Reaction score
- 858
I've had Koni's and Intrax laying around for a few weeks now and decided to finally start this process from **** today. Here is a strut I've removed from the "experiment" (my car) and this is also what the other three corners have bolted in. I had assumed suspension on this was stock since it's so bad and I've looked under there before. I mean I've had the wheels off plenty of times for brake jobs (seized caliper when I obtained the car), wheel changes, and a 60k, but **** they were so damn dirty I guess I never noticed their blue color. So I'm assuming this isn't stock... struts anyway; the springs are just blank, black, awful looking springs. These are not light blue like Tokicos.
To the point, what are these and can one insert Konis into them?
Made in USA
780 P134
Check out my goodies
I'm not going to wait around in limbo for a response on this... when I get time later this week (****, hopefully tomorrow night) I'm going to go ahead and drill the small 3mm hole in the bottom of it to release pressure, then hack and remove the guts. Then I'll decide if the Konis will fit inside and drill the larger 14mm hole if they'll work. Length and diameter wise they look like they will work but I figured I'd post up and see if anyone has experience with these before I get to drilling and hacking, maybe someone can save me some time. I've never seen blue housings with Konis before, but I know Monroes will work and obviously Ford units. I'm going to be ****** if I can't use these.
Made in USA
780 P134
