hawkeye18
Sorta cares
Aha, that's right, I remember that now. It is the same in the '90 EVTM (or at least close enough as it makes no difference).
So yes, you can disconnect the alternator entirely purely for testing purposes, just be sure to isolate the wires you disconnect, as at least two of them will be hot (all the time in the case of the big charge cable, and when running in the case of the red/green wire). Of course, you will get a battery light on the dash while doing this.
Actually, I don't think you will get a battery light, since by disconnecting the plug you are removing electrical continuity - since there is no ground and nowhere for the electrons to go, nothing will happen. Now, if you were to short that wire to ground...
I don't actually know what he was going for there, so I'll let Mooby answer that one.
