Crunch Crunch, now with pics of destruction
92sho16
b00sted
Liverpool, NY
[YOUTUBE]<object width="640" height="385"><param name="movie" value="http://www.youtube.com/v/7C_0FwrHjzE&hl=en_US&fs=1&"></param><param name="allowFullScreen" value="true"></param><param name="allowscriptaccess" value="always"></param><embed src="http://www.youtube.com/v/7C_0FwrHjzE&hl=en_US&fs=1&" type="application/x-shockwave-flash" allowscriptaccess="always" allowfullscreen="true" width="640" height="385"></embed></object>[/YOUTUBE]
So i guess i lost my forced induced SHO virginity yesterday.
862a2509
B68bbff8
666c8175
193c02eb
St Louis SHO
Rollin' coal
0 .· ` ' / ·. 150
When you go to your youtube vid, copy the embed link, it should be somewhere near the vid screen, then place that into your [youtube ] brackets
[youtube]<object width="640" height="385"><param name="movie" value="http://www.youtube.com/v/7C_0FwrHjzE&hl=en_US&fs=1&"></param><param name="allowFullScreen" value="true"></param><param name="allowscriptaccess" value="always"></param><embed src="http://www.youtube.com/v/7C_0FwrHjzE&hl=en_US&fs=1&" type="application/x-shockwave-flash" allowscriptaccess="always" allowfullscreen="true" width="640" height="385"></embed></object>[/youtube]
gmorrell
Never been a noob...
Colorado Springs, CO
Don't know if you're going to rebuild that (crash) box or not, but if you do, inspect all the other gear tooth faces with a fine tooth comb. When I re-shimmed PanamaPat's 3rd gear grenade MTX, I found a tight spot at two places in the ring gear rotation. Turns out a tiny sliver of 3rd had embedded itself in the face of a ring gear tooth, and it bound up each time that tooth went through the 1-4 and 5th pinions. Had to replace the ring gear, as the tooth face was bumped up around the embedded sliver.
Sorry to see that happened, it sucks.
92sho16
b00sted
Liverpool, NY
I had another mtx laying around as i was sort of anticipating this was going to happen after all the reading ive done on here. Right now i am looking into options of a engine transplant because swapping a transaxle was a pain, didnt take long but i dont think i want to do it again.
AREA 91
Area 91
What kind of number's is your car pushing???
Toolman
Boost it!
Grand Lake, Oklahoma, USA
I think he is using my old turbo and 3.2. If he is around the same boost, 13-14, he is making 365ft lbs. Assuming he has no other mods.
