My new wheels :P
Mr95Gl
Mr Tire Iron
Brooklyn, N.Y.
Definitely one of my favorite SHO wheels, but what's with the wheel gap? Car on jackstands?
GeneSHO
Canada
Im just curious. I should know this because I have been around long enough but the Cobra Rs for the T-bird, are these 17x9s?
For your info. Details copied right out of the Ford Motorsport Catalog.
SILVER THUNDERBIRD-COUGAR WHEEL
M-1007-E177*
Sold In Units Of Each (1)
Suggested Retail $195.00
Dimensions: 9.50H x 18.75W x 19.25D
Weight: 24.10#
Catalog Page: 87
Instruction Sheet: N/A
M-1007-E177*
Fits 1989-97
5-lug, 4.25" bolt circle
5.57" backspacing
17" x 7" wide
Includes center cap
M1007E177
SHOspazz92
Banned
Triad Area, North Carolina.
I didn't think one could get RWD rims to work on a FWD vehicle...guess that proves me wrong! What are the details on those rims (diameter, width, offset, bolt pattern, etc)? They look nice, and would show off some nice cross-drilled rotors behind them!
MN12 Thunderbirds had pretty much a FWD offset wheels from the factory for whatever reason.
-Sam
_JR_
Toronto, Ontario
New suspension put in right before i put the vehicle into storage. Still needs to settle a bit.
Also i plan on the cobra brakes so it will fill in the fronts a bit ;)
The way i drive, I'd go through cross drilled rotors like butter. Plain/vented for me :D
Biker and i should start an elite club for MB's with the SVT cobra r's (and yes i know they were meant for the t-bird but they are cobra r's for tbird fitment)
biker889
Quakertown PA
mine is sitting on intrax and koni's still debating if i want to cut a coil in the front, i probably will...
Here is my next upgrade
1206091102
randy'sho
95 White MTX
High Point, NC
17x7 is the only reason why I dont like'em; but athestically they look awesome
yah you're right you had better stick with the slicer...hahaha! I had a friend when I was younger that always said "if I had that it would be better than yours"...took me back for a minute!
_JR_
Toronto, Ontario
I also use the same size tire. I bought a set of used tires off of Kris (DdakRT) and they are awesome. It's pretty easy to peel out/break traction with the tires, the rubber seems rock hard. Huge improvement over slicers with the goodyear A/S tires.
19sho90
Colorado
Question guys. These are the Tires i want for my SHO. But what Brake upgrade will i need to do? Cause these will not bolt right on to a 90 will they?
SHO Continental
Moderator
Northridge, Cali
Those are aftermarket Cobra R wheels made by SVT to fit the Thunderbird. They are in the correct 5x108mm pattern to fit the gen 1-4 Taurus.
Staff online
