trainguy1989
SHOtarted
I had a front 60K done to my 91 MTX. I have a noticeable whine under throttle and an oil leak on the front of the engine that did not exist before the 60k. The car only leaks oil when it is running. I believe the whine is from an overtightened timing belt. Is it possible for the belt to be so tight that a front main or cam seals got squished? Pulled the upper timing cover off and saw that the belt already has its markings worn of with a bunch of black dust inside. I do not have anymore than 4 miles on this belt.
Thanks for the help,
David
David
