Sticky seems to indicate these calipers will work:
94-07 TAURUS/SABLE/SHO
95-02 CONTINENTAL
Spot checking on Advance Auto Parts, it looks like the 01-07 caliper is different from the 95-99 caliper. If you look closely at the pictures, both use the FN74 bracket. So, is there anything to be concerned about? Is the newer design caliper from 2001+ any better than the older ones? They are $16 more each.
With any luck these links will work so you can see what I'm talking about:
2001-2007: http://tinyurl.com/ydf5qvs
1995-1999: http://tinyurl.com/y8exgyf
I found some Junkyard 95 Lincoln calipers, and some 2001 Taurus calipers that are more expensive. Want to make sure either will work.
95-02 CONTINENTAL
