quite an increase on just a tune
SuperHO
Mental Patient
St. Joe, MI
oh my...could be a repost, but don't really give a damn.
[YOUTUBE]<object width="560" height="340"><param name="movie" value="http://www.youtube.com/v/JNigmGSvu3k&hl=en_US&fs=1&"></param><param name="allowFullScreen" value="true"></param><param name="allowscriptaccess" value="always"></param><embed src="http://www.youtube.com/v/JNigmGSvu3k&hl=en_US&fs=1&" type="application/x-shockwave-flash" allowscriptaccess="always" allowfullscreen="true" width="560" height="340"></embed></object>[/YOUTUBE]
SHODWN
Mother Threasa
Spencer,Ma usa
Since when did we start dynoing in 3rd gear?
3rd gear is 1.414
4th gear is 1.000
Still nice gains! but not correct ratio.
PonySHO
FOG
Joe's Garage
The specs I saw showed 5th was 1.000 and 4th was 1.414. I was surprised, since it was a 6 speed I assumed it had 2 overdrives. 6th is 0.742.
beefcake
cincinnati, ohio
How does this compare to the modular depot tune?
I will tell you this much. These cars have a lot more paramaters than anything Ford tuners have worked with before.
One tuner already lost a motor right out of the gate.
Do not and I repeat do not get hung up on dyno numbers.
As far as MD's tune. Everything was done on the street, not a dyno.
The car picked up from a 13.84 to 12.75 with a tune. I did have the pass seat removed compared to stock which is probably good for half a tenth or so. The car went 12.9's several times in not as good conditions with the seat in.
The guys at MD know their stuff!
Flash Gordon
Central Florida
I am one of the tuners that is involved with that project and would just like to respond.
First, SHODWN, about the concerns over which gear the car was pulled in. Normally I would agree, that most vehicles should be pulled in 4th (or the 1:1 ratio) and whenever possible, I do. On this one, however, in order to have impartial results (and the fact that neither of us has an AWD dyno) we took the car to a third party Mustang Dyno and allowed the dyno operator to strap the car down and perform the pulls. Our only involvement (at that point) was the installation of the tune. We had already done most of the R&D on the tune by that point. Yes, the car was pulled in third gear. It was also pulled in fourth, (forget 5th, 4th took long enough) but the difference in power was negligible. In fact, if anything, it probably would have shown a slightly better gain if pulled in fourth. The dyno operator suggested doing the remaining pulls in third. Since this was a Mustang Dyno, it was loading it properly, and we already verified that there was no power difference, we did not argue. I will see if I can find the sheets to illustrate what I mean and post them here.
Beefcake,
You are correct, these cars tune like nothing else that most of the tuners out there are used to. That is why you only see a handful of tuners tuning them. They are speed density, and have computer controlled turbos similar to what Ford has been dealing with in Europe for some time. Direct injection is also new to the US, but it is nothing that a good tuner cannot learn (if they have not dealt with it already).
You are right, Ken is a good tuner. I am not trying to take anything away from his accomplishments or yours. I am simply here to do my own thing. Our tune is mainly focussed on driveability, not top end horsepower, but we tested it anyway. Needles to say, we were happy with the results. We could have gone further (and we probably will), but for right now it is safe. In fact the car has had 2200 miles since that tune was installed without any problems whatsoever (not counting all the testing that led to that file). I was hoping to compare it to some other dyno numbers, but unfortunately we have yet to see any. The car that we are testing on ran a 14.1 stock. Unfortunately, the track by him closed before we could get the after numbers. We will be getting some times soon though. In the meantime, keep up the good work. I like what you are doing with yours.
James
BTW, NiNeTy Fo SHO, yes the AFR is plenty safe.
shobote
Naperville, IL
Does your MD tune also require 93 octane for those numbers ? Can it also run on mid grade or is there a switch to go back to stock tune on the SCT ?
beefcake
cincinnati, ohio
it's not a flip chip like the older cars, it's a flash tune,
it's a 93 octane tune. if your turning the wick up on your car, i wouldn't run anything less, unless your running 91 because thats all you have, then i would have it set up for that
SHO Dude
Southeast
James is a close friend of mine. His work is very good.
We now have the tuning for these as well.
