it's not a flip chip like the older cars, it's a flash tune,
it's a 93 octane tune. if your turning the wick up on your car, i wouldn't run anything less, unless your running 91 because thats all you have, then i would have it set up for that
I would imagine that you can load a base map and a real time map on the fly. The base map WILL be the new flash and it will default to this tune anytime power is cut. A real time map can be flashed in a matter of seconds and will be lost when power is cut (remove battery).
