Stubborn bolt
elarm1
Maryland Native
Woodbridge, Va
A day and a half leads to success! :sun:
Tools used:
Air chisle
1" hole saw bit (3)
Dremel
Air Dremel or whatever its called!
Photos151
Photos152
Photos153
jmpSHO
Massachusetts
I doubt it's crank cancer, just replace it with a crank bolt that's in decent condtion and you should be fine.
ShadetreeSHOguy
Postwhore
Dallas, Ga
yeah, dont put any kinda aintisieze or anything on the threads. the best thing i can do inho is just tighten the **** out of it and just be super careful if you have to bust the bolt loose again
pjtoledo
'ol man in the SHO
toledo,ohio,usa
What can I use to stop this bolt ****** from seizing to the crank pully again?
anything. grease, anti-seize, oil. anything that will seal out water and slow corrosion.
you got the ****** part exactly correct, thats what sticks. as stated earlier, don't put anything on the threads.
msteiny
Grand Forks,North Dakota
Holy Crap I thought mine was stubborn. Seemed like nothing would get mine off. I ended up using the serp. belt to hold the pulley. I wrapped around the crank twice then went around the A/C pulley, around the Alt. and then back down to the A/C. But this time under the belt that was already there, this way the belt would tighten against itself. 1/2 breaker bar, 3 foot pipe, one hand on my nuts and a couple good pushes and POP! I almost quit when I looked down and seen how much the breaker bar was flexing but figured what the ****. I guess after what you went through mine doesnt seem so bad now.
shonuffmine
wildchild
sweating balls in fla.pan
I,m gonna have to disagree about runing the bolt in dry!!! ALWAYS use some light oil or assembly **** on all bolts.when torque specs are called out it is for a wet or oiled bolt! grease on the ****** is a great idea,thick enuff to keep the moisture out.Also malox antacid is a great anti-seize, i,ve been using it on header bolts since 1976. If ya use the cherry flavor it makes your ride smell purdy LOL
