Sensor on top of coolant bottle
Mr Josh Zombie
SHO newb
Toledo, OH
What the **** is it, and what does it do? :lol:
When i was resetting the PCM today, i noticed that the sensor wasn't plugged in.... Thinking someone probably removed it by accident I plugged it back in.
Well, i went to fire the car up. It started, stalled out, and smoke came from this sensor. I quickly shot up, disconnect it, and tried to start the car again. Low-and-behold, i blew a fuse. Replaced it, and the car fired up again.
So, who knows why that would be disconnected and blowing a fuse when it's plugged in?
Brett
SHOs before HOs
Minnesnowta
low coolant light on?
hawkeye18
Sorta cares
Norfolk, VA
it's the low coolant sensor, and it broke. You just found out why the PO had it disconnected! This is "the sensor that keeps your car from starting".
Mr Josh Zombie
SHO newb
Toledo, OH
funny enough, no low coolant light on. and what do you mean by "sensor that keeps the car from starting."
with it disconnected, it starts just fine. ****, with it connected, it starts just fine until the thing starts to smoke haha.
good to know it's not important at least.
projectSHO89
SHOless In St L
St. Louis, MO
The sensor is wired to one of the circuits (Ignition Coil) that is necessary for the car to run.
When the fuse blows due to a defective sensor, the engine quits.
projectSHO89
SHOless In St L
St. Louis, MO
Really? I think my low coolant light has been on for a year, engine runs perfect.
No. There are several different failure modes. The most common is an internal short circuit that blows the fuse.
Yours is likely just crudded up and needs a good cleaning.
sho'noffmtx
Many SHO's
Delano,MN
My ATX did the same thing except i was driving it when it happened. Talk about panic!! As mentioned before the sensor is shot. Junks yards are now your best friend.:)
Hap3niz
Texas
.. for some reason, it messes with my fuel pump, lol..
at times, the FP wont come on.. so i go and wiggle that fuse..
everything works..
oh, the low coolant light does come one.. kinda fades away.. back on.. the off, haha..
crystizel
