when i turn the sterring my engine moves?!?!?!
llamaking122
Green Machine
Columbus, Ohio
ya so i tried reseting the idle and i noticed when i would do the 1/4 spin it would move the engine what is that
1993MTXSHO
Its a Taurus...
Jersey
Yup, sound like you need new subframe bushings, or need to crank them down again. But if you still have the factory rubber ones, just go get some aluminum ones and be done with it. The handling difference is incredible going from old worn out rubber to solid.
llamaking122
Green Machine
Columbus, Ohio
thanks yeah when i was at the oil change place he took me down to under the car in the pit and i knew they were junk but didnt think that it would do this
shocrates
will never know
NJ
+3 definitely subframe bushings.
I don't know what stock SFBs cost, but I do know aluminum doesn't wear out and it will be the last ones you have to buy.
On the other hand, the aluminum SFBs will bring out any weak links in your front suspension.
llamaking122
Green Machine
Columbus, Ohio
ya i just have like no money so if i have to i can i know i will in the future if i dont
