Cylinder wall corrosion
Racer X
SHO Pilot, Retired
Connecticut
So, I took apart the 3.2L to check up on an oil burning issue. I found 12 of 12 leaking exhaust valve stem seals, and while the rings looked ok, I found a problem with the #1 cylinder:
P1010010
If I run my finger up and down, I can feel a profile. Is this fixable, or am I completely [screwed] and going to need a new 3.2L block?
St Louis SHO
Rollin' coal
0 .· ` ' / ·. 150
I'd hit it with a hone and see if it removes the profile. Then (if you can) measure the bore to see if its still in spec. I'd have to lean towards a stuck ring by lookin at that spot on the wall :(
Edit: I see you already tore it apart Doh!
Racer X
SHO Pilot, Retired
Connecticut
Haha yeah it's already in pieces, the block is strapped down in the back of the Cherokee.
I've been running it for almost the past 3 years now and only recently took it off the road. Before that, it sat for a while in a storage shed before I bought it, however during my initial inspection, there was no hesitation when I cranked it by hand.
Racer X
SHO Pilot, Retired
Connecticut
Just heard back from the machine shop. He said the honing cleaned up 99% of it. Looks like this engine will live out the rest of it's days as a 3.2L. :)
I'll have pics when I get it back from the machine shop later today.
yamahaSHO
E85 whore
Arkansas
Like I said, more faith than me. With how cheap and easy you can get a block, it's not something I would do without completely boring it out.
AREA 91
Area 91
P1010010
I know of at least 2 SHO engines that looked like that. Both are still running to this day.
I still find it hard to believe that a hone (and a hone only) is aggressive enough to remove visible ridges. I would have thought you'd need to cut at least 20 thou...
Guess there's hope for more heavily damaged blocks than I thoght.
I'd love to see before and after compression ring end gap numbers.
AREA 91
Area 91
The last one I measured was just in spec, as far as ring end gap.
