WTH? Plastic Front Stabilizer Endlink!
swami
No. VA
when i took the front wheel off to do the '96 brake upgrade i saw that piece of plastic and said wth is that. i can't believe ford would put something like that on a SHO. i see rockauto has a patented improved METAL endlink. what's everybody else doing? TIA
Mr95Gl
Mr Tire Iron
Brooklyn, N.Y.
The plastic design is perfectly fine if you live in an area with relatively smooth roads. That and their lighter (negligible) if your a weight savings fanatic. My own personal experience with them out here has been that they won't last very long with rough roads.
shobote
Naperville, IL
Iv'e had my plastic Ford endlinks on for 5 years and no problems. I like that they are lighter and also selaed, and not greasable joints, like the metal ones.
The nylon parts are considered an upgrade from the earlier metal parts - they are actually stronger.
hawkeye18
Sorta cares
Norfolk, VA
Believe me, those plastic endlinks are plenty strong for any driving you'd do (i.e. not doing the Baja 500 with it). They only go through tension and compression, two areas in which plastic excels. Torsion, it doesn't handle so well but those end links don't go through that.
Shoaz
Studly dood
Scottsdale, AZ
IMHO the plastic parts are the most desirable. They're plenty strong and they're far lighter than the metal parts.
Might be considered an upgrade, but if you believe that they are stronger than the steel versions, you are on crack.
They're plenty strong enough to do the job. I've never seen (or heard of) one failing due to inadequate strength.
SuperHO
Mental Patient
St. Joe, MI
living in Michigan and dealing with the moonscape we call roads, I'd much rather have the peace of mind of having them sturdy, beefy metal ones (mine are sealed, by the way) than having to replace em every 6 months due to some absurd crater that somehow got overlooked by our remarkable department of public works.
just to give some of ya'll out of staters an idea of what we michiganders deal with on a daily basis....
[youtube]<object width="425" height="344"><param name="movie" value="http://www.youtube.com/v/1PA1J0oDphc&hl=en&fs=1"></param><param name="allowFullScreen" value="true"></param><param name="allowscriptaccess" value="always"></param><embed src="http://www.youtube.com/v/1PA1J0oDphc&hl=en&fs=1" type="application/x-shockwave-flash" allowscriptaccess="always" allowfullscreen="true" width="425" height="344"></embed></object>[/youtube]
I've had morning commutes to work like this...
boat
Likes blue ones
Tallahassee, FL
I have the metal greasable ones in my 94, I like them. :thumb: More of a peace of mind.
SHORANGERBIRD
Restorer of SHO
Alexandria, Alabama
-if anyone can remember way back when....in the beginning years of the taurus and SHO, they were metal, then Ford switched to the new design nylon ones. and they are quite strong and never had problems with them. the ball socket usually gives way, normally by the boot tearing and dirt/water getting in....
zak
east of Hartford
The material actually has fiber reinforcement in it IIRC. Pretty soon commercial airliners will all be made with fiber reinforced plastic, best get used to it . . . .
zak
SuperHO
Mental Patient
St. Joe, MI
last i saw, there weren't too many commercial airliners bouncing through michigan potholes deep enough to break the ball out of the socket of an end link.
yamahaSHO
E85 whore
Arkansas
I'm sure Pat McGrath has metal ones, but he bent his front sway bar (20.6 IIRC) a couple year back after hitting a very rough train track in the road.
swami
No. VA
i have a 20.6 front swaybar. got a 26mm for the rear when i redo my suspension.
