Worn front strut-rod bushings....
mikiedreb
Benicia, California
What at the symptoms of worm strut-rod bushings? I've been trying to diagnose a jerking/rubber-band effect when going from on-to-off-to-on throttle. I've been under the car several times checking and haven't seen anything unusual.
You help would be greatly appreciated....I'm going to need a neck brace soon !!!!
Mike
92MTX
stevetatro
Cincinnati, Ohio
You mean the rubber bushings where the strut rod is bolted to the subframe? If you can still see the rubber (meaning they haven't totally disintegrated) they should be okay. Can you feel any play if you tug back-and-forth on the strut rods?
