Fordlover96
Hey guys, what's up?
My 93 ATX just hit 89k the other day and has been running great. Hasn't really given me any real trouble in a long time. Other than a blew heater hose (again) and this transmission issue, the car has been flawless.
Now, this is the weirdest thing. Okay, how do I explain it.
When the car shifts into fourth gear (usually at 40) about 70% of the time, the torque convertor lockup will do some weird shit. It will lock up, RPMS drop, at around 35 and then when the transmission shifts into fourth it will disengage and then engage again. You can physically feel it in the car. RPMs will jump way up and then back down.
The reason I say its the lock up and not a slipping shift is because the other thing it does is at highway speeds. Doing about 70 if I push the gas about an inch, the RPMs will drop way down and the thing will pull. If I pull my foot up, but not completely off the gas, the lockup will pop out and the RPMs will jump way up. So just cruising the lockup isn't engaged.
The car never did any of these things up until a month ago.
Any ideas? I've swapped out the throttle position sensor and let the car sit without the battery disconnected over night. The later did help for a couple days then it returned right back to doing the weird thing.
