Winter Tire & Wheel Combo - Will It Fit?
Chip Raffi
Sandown, NH
Will this size wheel fit my 2010 Taurus SHO? My stock tires are 245/45R20's.
✓Bolt Pattern: 5-114.3mm or 5x4.5"
✓Offset: 39mm;
✓Center-Bore: 63.4mm;
All the dimensions look right, but caliper clearance does vary by the specific wheel in question. You have a Gen 4 SHO, 2010-12, which has 13" rotors.
https://shoforum.com/index.php?threads/winter-rims-will-they-fit.136835/#post-1482975
With a spacer 17s could be an option
https://shoforum.com/index.php?thre...heels-that-could-work-for-winter-cars.139266/
I usually see Ford giving 4 inches of clearance minimum over the largest rotor size for a vehicle line. So 13" rotors, minimum 17" wheels. That kind of thing.
Chip Raffi
Sandown, NH
Thanks - that’s good feedback and valuable insight. So the 18’s I mentioned could work based on offset needed, without the need for spacers, if I’m understanding you correctly?
Brumfield780
