Window Lift Motor - New England Style
Rockledge
Pluggin' away
Connecticut
Well folks, this is what both of the rear window lift motors in my '94 SHO looked like. After the switches tested out fine I pulled the motors and I found they were all corroded and siezed up. Nasty, huh?
The good news, I guess, is that I was able to salvage one of the motors by taking it apart and cleaning it with solvent and compressed air, freeing it up with some penetrating oil, and then applying a little white lithium grease to the gears before putting it back together. Not a very difficult job at all, just took a little time.
Rust is bad, but does this have any relevance to the engine and driveline? doh
Rockledge
Pluggin' away
Connecticut
Oops! doh
Well, I'm sure the powers-that-be will be booting this thread into the right forum soon enough... hail
And yes, rust is bad ...so let's hope there's none going on when I go to replace my Subframe Bushings! :D
(Oops...the SFB subject doesn't belong here either! lol ).
<small>[ November 25, 2003, 11:24 AM: Message edited by: Rockledge ]</small>
Blue-By-U
CT
My rear window motors looked the same with all that rust. I just replaced them with lower mileage versions and kept the old ones around for emergency spares.
Rockledge
Pluggin' away
Connecticut
Blue-By-U:
Alex, the inside of your doors, where the motor is mounted to the bracket, probably looked like this, right?
I ended up cleaning the bracket with solvent and a rag, and then I used a wire brush bit on a drill to get the rest of the rust off. Nice and clean now. wink
crystizel
