Which setup?
jacen2912
Numba 12
Redford, MI
So here's my situation. I currently have a stainless-steel flex pipe true dual exhaust setup with only one cat (on the rear bank, but no 90-degree bend). It has two "resonators" (AKA in-line glass packs/cherry bombs) and then two tips that act as "mufflers" (AKA glasspacks again). It is louder than a Metallica concert. I want to quiet it down. Here are my options (due to finances):
1. Put some mufflers on the current set up and call it a day.
2. Go to the exhaust shop I go to and, for $220, they will make a stock set-up using the "mufflers" (glasspacks) I currently have. they will take the dual exhaust setup, eliminate both of the pipes from the cat-back and make it a single-pipe dual tip set up (stock). But I will retain those glasspack "mufflers".
3. Buy mufflers from a local parts supply place for $60 (thats right 60 total) and have the exhaust shop include that in the $220 build of my exhaust.
I'm not looking for performance, or loudness right now. What I want is to know my car is on, but not wake up the neighbors when I want a late-night fast fooding.
Either way, I'm doing something about this tomorrow. The cops are following me a little too closely lately, even if I'm not in the wrong.
TYSHO
Earth
I'd go with number one. The second choice doesn't look to solve any problem with the noise, just a different design.
jacen2912
Numba 12
Redford, MI
What I ended up doing was a whacked out version of #3.
I got the mufflers and went to the exhaust shop but the built the exhaust in a fantastic fashion. They started out by eliminating all things flex pipe. Anything that was flexpipe was removed (that includes the front bank's representation of a y-pipe). They then constructed a custom-bent no 90-degree angle Y-Pipe and relocated the one cat I had to the section of pipe after where the two banks make one pipe. From there, they built a stock exhaust back to those mufflers I bought which also are stock.
Now I have a stock system with only one cat and a custom-made y-pipe that looks like it would flow well. I could not be happier! it's a bit tinny in the back as I have no resonator, but that can be fixed later. I have my power back on the freeway! The punch of the pedal in 4th or 5th and 70 mph does something now! Man and for $340 otd? NOT BAD.
