where to get front motor mount
t5535
Sioux Falls, South Dakota
I have it out of the car. I thought I could just order one from the parts house but guess what nope lol. I think I mite look into fixing it.
AREA 91
PA SHO SHOP
Area 91
I have several sets of reinforced mounts on my shelf.
P.M. if interested.
jayro
Auburn, In
How bad are they, and how aggresivly do you drive the car? I reinforced mine with some bolts and urithane from McMAster Carr. I know alot of people that just go with the bolts and are happy with them. if your not wanting to do it yourself, then there are a number of forum members that have them avaliable.
jayro
Auburn, In
they are not to bad. the rubber is still there but they are seperated. This looks like a inexpensive and quick way to fix them. Im just currious about the end link bushings. are they gonna help vibration?
http://www.shoforum.com/showthread.php?t=99078&highlight=reinforced+motor+mount
From my understandng you dont need the endlink bushing. If you are bolting it together, you would be keeping the rubber in it correct? Im not 100%, but I would think keeping the rubber would be plenty to handle the NHV. I know my vibration increased, but mine are bolted and then poured with rigid urithane.
frosho
WOLFMAN
Tyngsboro, MA
You're going to have a lot more vibration under acceleration if you decide not to use any bushings between the bolts and mount. Just FYI.
Use fat, strong (grade 8) bolts and they will hold.
t5535
Ok I put the bolts in 4 grade 8 with no bushings. vibration incresed quite a bit at idle. gonna try and put some bushing in there to help it. the vibration is not that bad but still dont like it. makes me think the car is not running right ya know. When RPM is incressed the vibration mellows out quite a bit.
