where do i get gaskets?
Irish Pride
Irish Inside
MusicCityUSA
in the rear future i'm going to be porting my runners and adding some bbbs. when i go to install them, where do i get the gaskets to go with them? do i just cut regular gaskets to fit?
NovaSS
Project MINIGUN
%99.9 of the people that do this just open the ports to the size of the gasket, the hole in the gasket is already larger then the factroy port. With the BBB you dont use the air horns so you will have an extra set of gaskets when done.
Phoenix
SHOHOLIC
QC , Canada
Ditto , the only gasket I ported was the exhaust manifold gasket to fit the holes. The rest is already bigger , so you port with an old set of gaskets , match the holes and voila.
