vibration in front end at 70 mph
pete315
Long Island, N.Y.
at highway speed, I get a vibration in front end. tires are balanced and car has new outer tie rods. I can feel in the steering wheel like something is loose. any ideas where I should start checking?
AREA 91
PA SHO SHOP
Area 91
:thumb: Make sure taht your CV shafts and wheels are torqued to spec. I had a CV shaft start to losen up, caused the exact symptom you discribed.
SHO SPD
SHO member #480
Naples, Florida
Verify that your inners are good as well. Check make sure your tires arent out of round or have a broken belt. as well as the above
pete315
Long Island, N.Y.
I had the rotors cut about 10,000 miles ago on last brake job. how can I tell if inner tie rods are bad? how do you change them? changing the outer tie rods was easy.
ShelbyDoug
NY
If everything in the suspension is ok, then it's most likely a bad tire. If the tire is bad, even rebalancing it won't help. You will need to change it.
pete315
Long Island, N.Y.
well, I found my problem. jacked up front end. no play in right tire. when I grabbed left tire at the 9 & 3 position, I had so much play. the outer tie rod that was changed last year was shot. I don't know if it was defective or just ran out of grease. the boot was not ripped. when I removed tie rod, the joint was just flapping around. well at least it's a cheap and easy fix. $25.00 for part, now it should drive like new again.
pete315
Long Island, N.Y.
ok, I just put the new left outer tie rod in. I take it for a test drive, and now I have unbelievable torque steer. it pulls hard to right on acceleration. I never had that before. I just counted the # of turns when I removed tie rod. could a bad alignment give me this torque steer? I car pulls slightly to the right when driving but when I put my foot into it, she pulls a lot harder.
SHO SPD
SHO member #480
Naples, Florida
The counting gets you close, but you definantly need and alignment after those kind of jobs. Go get that done and see what happens toe wont cause a pull. camber and caster do though.
pete315
Long Island, N.Y.
I just got front end alignment. torque steer gone. drives like new. I guess you can't do a front end alignment with 1 eye close and your thumb as a measuring stick :bonk:
tinkerkathleen
