valve cover bolt
mattsho1993
SHO owner
albion, new york
On the side of the valve cover the two bolts, how crucial are they? mine came almost all the way out when suddenly they snapped!
jmpSHO
Massachusetts
This happened to me also and you definately need them. I ended useing a nut and bolt on mine but I guess it depends on how much snapped off. Mine had enough metal on the top for a bolt to sit on. I can take pics tomorrow if you want. Just a side note if you use a nut and bolt just tighten it a little because it will clamp down too much and the timing chain will hit the valve cover.
jmpSHO
Massachusetts
mattsho1993
SHO owner
albion, new york
ill try and ez out it if that doesnt work ill drill it out but im def. gonna try the nut and bolt thing how tight should i do it just a little more than snug?
jmpSHO
Massachusetts
Mine broke when I tried the EZ out and if you use the nut and bolt just snug a little bit. I torqued mine to factory specs and it was too tight, the valve cover ended up hitting the timing chain so I loosened it and it's fine now.
jayro
Auburn, In
This happened to mine. I drilled mine out and then put a bolt all the way through with a washer and lock washer on the back. On the front I used the rubber gromet washer off the original bolt. Worked like a charm.
If you could get the rest of the bolt out with an ez out you could use a tap to clean up the thread and get a good bolt from a forum member.
mattsho1993
SHO owner
albion, new york
ok guys so i changed the gaskets sanded the valve covers and painted them ford blue ill get pics tom., anyway so i had a extra set of intake gaskets laying around. So i sanded the runners and tanks on the plenum got rid of all the casting blemishes and paint! Needed to drive it so i had to throw them on, the girls car shit reverse. So its not finished but id like your advice feelings and what not as to what you think! I want your advice on what to do with the engine bay as well!! I have a blue SHO and a black engine bay what do you think about painting the bay the same blue i have the valve covers ford blue and the MAF i plan on getting color matching (Blue) vacum hoses and coolant hoses, just wanna pick some brains about ideas!! ill get pics tomorrow....
