V8 cam sprockets & Locktite
stephen newberg
Ladysmith, BC, Canada
I do not know if everyone is reading the folder on V8 camshaft fix, so I am going to cross post this to make sure everyone interested can see it.
Well, this got me thinking about it all again and I decided to actually ask an expert, so I went down to Balcomb Metals yesterday and sat in Harry's office for a bit and then got take out to the shop to be shown some more things. It took a couple of hours, but here is the gist of it.
First, the cam/sproket attachment system used is not at all uncommon, and will likely never cause a problem. The ones that do fail will likely be random failures do to an off angle during the mating or a problem with the expansion pressure applied. With about 50ish failures out of 15,000 in use, Harry advises to stop worrying.
Second, if you are still worried, Locktite is the way to go. He puts metal together with Locktite all the time, and for situations under huge stresses. Works great. He suggests using the breakable version (Red, I think he said, but it might be Blue because we talked about both: regardless, it says on the tube), just in case one day you want to be able to get the sprokets off, but if you think should that happen you are going to replace the cams at the same time anyway, go for the unbreakable version. It is stronger and it really does not break. He says this application is perfect for the way Locktite works so long as the sprocket is nhot already slipping, just wick it in until it will not take more, and be sure to have a catch tray under the application area. Obviously, the joint should be cleaned with a non-residue cleaner first.
Harry has been putting metal together for a living for 40 years, with keeping the internal parts of engines in one chunk as a major line of his work. I would guess he knows exactly what he is talking about. So, if you want to have peace of mind on this, go buy yourself a tube of Locktite, pull over the covers, and glue away. Cheap, effective, and then you can stop worrying.
pax, smn
<small>[ March 13, 2002, 07:45 AM: Message edited by: LASTSHO ]</small>
elcapitan87
Clarkston, MI USA
Yes, but is this guy putting together metals that have been covered in oil for a few years? I agree that the proper Loctite can be a great way to permanantly affix metals, but I'd be concerned with using Loctite as a solution on cams that aren't entirely devoid of any contaminants. If thats the route that you want to go for your piece of mind, I'd just make sure that you clean those SOBs up good before.
My $0.02
stephen newberg
Yes, Harry has been putting together metal that has been in oil and lots of other strange things for a good part of that time. He is one of the ones they call when they need strange stuff fixed on the offshore rigs.
Obviously you are correct about getting the metal clean first. There are piles of solvents available that do this and do not leave resulting residues. Harry said his favorites are the ones used to clean electronic contacts in enclosed pots and the ones used to clean brake parts.
pax, smn
SHODWN
Mother Threasa
Spencer,Ma usa
plug all your return holes, and cover your vlaves. it solvent gets in the oil or goes down the valve spring and then down the rod you will wash out your bearings. then you will be fixing your lower end and not the top
