vsofouk
OK... So the car is really sluggish when the engine is cold below 4k. It feels like it's falling on its face. I did a full 60k on it in the spring (it has 66k on the clock now).
No CEL or codes
I ported the intake and added BBB's during the time of the 60k too btw since I had everything off.
When I added the the high flow cat and the catback (with new 02 sensors) it got better
When I added the 73mm MAF (using the same sensor) it got worse
WIll the LPM tuning chip take care of it or do I have another underlying problem.
Before I did the 60K it had a similar problem - i noticed oil leaking in the plug wells - after the 60K the symptom did feel different. But I had the BBB and the ported intake on it already.
Once it's warm it doesn't hold back nearly as bad, however I feel that the low end still doen't pull as strong as it did when I 1st got the car. When it's cold outside it does run better. And 3rd gear is amazing now!
No CEL or codes
