JesseB
I had my half shafts replaced; both sides. After traveling 27 miles home; discover oil leak next morning. When the mechanic removed the right side, the half shaft became separated from the interconnecting shaft, a part fell on the floor; the mechanic picked it up; put it on the bench. I do not know if he remembered to put it back.
Anyway, my question is: If this was not put back in, could it have cause a leak? And should the retainer clip (3Z498); stop ring (N803655-8) and the bolts (N605904-S100) all be discarded and replced new.
Can anyone suggest what might have happen? There are no "broken" parts
Thanks
Thanks
