trans overheats any suggestions?
On my '97 the biggest improvement was to replace the factory steel lines with 3/8" ID hose. The factory lines are 11/32" OD and have crush bends in them. Plus I changed out the factory fittings with brass hose barbs drilled out to 7/16" ID. I also use a GEN 2 ATX cooler.
This keeps the temps down under the harshest of conditions. Much better than when I was running three coolers at one time. I also have the factory radiator cooler disconnected. In the winter I do have to cover part of the ATX cooler to get the temps up.
AREA 91
PA SHO SHOP
Area 91
The #1 auto tranny killer is heat. Get a big cooler on your car. You won't regret it.:thumb:
"SHO"time
shostopper
Detroit
i changed fluid already .bought lucas and put it in it helped a little but,its not going to cut it.were would be a good place to find a trans cooler
